iterating on elements of series - date in while loop
loulouviews
Postby loulouviews » Wed Mar 11, 2015 2:28 am
Hi everybody,
Here is my issue :
I have two series and I need to check whether some elements of the first series are equal to "na" and if it's not the case, copy paste these elems in the second series.
Currently, my code is as follows :
smpl %debprev %debsemep-1 %date=%debprev while @dtoo(%date) < @dtoo(%debsemep) for %i a1 a2 a3 a4 if @elem({%i}_ct(),%date) <> na then @elem(gm_{%i}f,%date)=@elem({%i}_ct,%date) endif next %date=@otod(@dtoo(%date)+1) wend
I'd like to know if there is any way to make it easier and faster since I need to repete this kind of things for a lot of series.
Thanks a lot !
Loulouviews
trubador
Did you use forum search?
Re: iterating on elements of series - date in while loop
Postby trubador » Wed Mar 11, 2015 2:58 am
smpl %debprev %debsemep-1 for %i a1 a2 a3 a4 gm_{%i}f = @recode({%i}_ct<>NA,{%i}_ct,gm_{%i}f) next
loulouviews
Postby loulouviews » Wed Mar 11, 2015 3:07 am
Hi @trubador,
Thanks a lot for your idea, I'll try that !
Loulouviews
