Import Error
ekyle
Import Error
Postby ekyle » Mon Mar 09, 2015 8:14 am
Hi, I'm trying to import data from Bloomberg. I've never had any issues fetching data, and can currently import simple indexes like spx, equities etc, but am having trouble with certain indexes. When I try to fetch from bloomberg I get the following error: "Database Error: Bloomberg library error: 'StartIndex cannot be less than zero. Parameter name: startIndex'. I haven't seen this before and could not find any similar posts about this specific error. Is there a way to get around it? I've tried fiddling with my sample dates and frequencies but nothing seems to work.
Re: Import Error
Postby EViews Jason » Mon Mar 09, 2015 8:51 am
Please list a specific series that is giving you the error message and we will look into it.
ekyle
Re: Import Error
Postby ekyle » Mon Mar 09, 2015 8:55 am
SBOICOMP Index
SBOICMPP Index
SBOILOAN Index
ekyle
Re: Import Error
Postby ekyle » Fri Mar 13, 2015 6:20 am
Any idea what may be causing this and how I can get around it?
Re: Import Error
Postby EViews Jason » Fri Mar 13, 2015 8:04 am
We are looking into the issue but as of right now there is no solution. The likely solution will be in the next patch. We will keep you posted
Re: Import Error
Postby EViews Jason » Fri Mar 20, 2015 3:09 pm
The next patch will have it fixed
ekyle
Re: Import Error
Postby ekyle » Mon Mar 23, 2015 12:59 pm
Great, thanks.
