Is there a way to save the rolling scores (preferably in one vector) when doing a rolling pca...
Currently my code is:
latam_5.pcomp(cor, eigval=eval, eigvec=evec) pc1 pc2 pc3
' store eigenvalue proportions which are rolling
!cumpc1 = eval(1)/@sum(eval)
evalpc1(!i) = !cumpc1
!cumpc2 = eval(2)/@sum(eval)
evalpc2(!i) = !cumpc2
' store eigenvals which are rolling
ev1roll(!I) = eval(1)
ev2roll(!I) = eval(2)
' store eigenvec (loadings) which are rolling
evec1(!i) = evec(1,1)
evec2(!i) = evec(2,1)
evec3(!i) = evec(3,1)
evec4(!i) = evec(4,1)
evec5(!i) = evec(5,1)
rolling pca scores
Re: rolling pca scores
You'll have to roll the sample, and store them at each observation. There are lots of examples of performing rolling operations on this forum.
Thanks for your msg. I've done this and only the latest pc1 saves (i.e. for last 2y window that I use). When I try to create a roll for pc1, it comes up with an error message. Have attached my code.
- rolling_pca_code_latam.prg
- (1.67 KiB) Downloaded 240 times
Could you provide the workfile too?
Workfile attached as requested.
Any help would be great...Many thanks.
Note: To clarify I've taken out the error bit in the previously attached code. The line that I had (to attempt to save rolling pc scores across the entire sample) was:
pc1vector(!i) = pc1
The problem is that pc1 is not a single value, but a 2y series. So what I am trying to get is pc1 scores at time t (2y window from start of sample), pc1 scores at time t+1 (window shifted one day), pc1 scores at time t+2 etc. etc.
What this does is updates all the pc's and adds an extra score taking into account the latest data from the +1 window shift. I can't quite figure out how to store this all into a single column vector/series (or even multiple series for that matter).
pc1vector(!i) = pc1
- latam_rollingpca.wf1
- (522.19 KiB) Downloaded 189 times
Well, as you say, you're trying to store a lot of data into a small container. It can't be done. If I interpret correctly, for each individual roll/sample, you need to save 730 values. Obviously that can't be done in a series, where you only have one value per date. Nor can it be done in a vector. Perhaps you should create 730 vectors? Or a matrix with 730 columns?
