I was running ADF-Tests with different specifications (trend, intercept) on various variables and wanted to create a table with the p-values (or t-stats) of each variable for each specification, to see at once whether or not I could reject the null of a unit root.
Now, I can't find any function with which I could adress and store the t-stats (@tstats seems not to work for the uroot view option...)
Is there a possibility to do so?
Thanks a lot and greetings from Vienna,
Anna
@tstats for a uroot test?
Re: @tstats for a uroot test?
Freeze the results into a table, then grab the number you want from that table:
http://forums.eviews.com/viewtopic.php?f=5&t=18
Thanks a lot!!
Why haven't I thought about that in the first place?
