Delete certain object types
JhonnyCa
Postby JhonnyCa » Tue Feb 17, 2015 12:00 pm
I want to delete all alpha objects (but not the series) from my workfile before structuring it into panel data. Since I have more than 5000 different objects (all series and alpha objects beginning with "_") in the workfile, it would be very inconvenient to do that manually. Unfortunately I could not find any options of the delete-function for this specific task. Thank you in advance for any suggestions!
trubador
Did you use forum search?
Re: Delete certain object types
Postby trubador » Tue Feb 17, 2015 1:13 pm
View/Select By Filter...
Postby EViews Glenn » Tue Feb 17, 2015 1:59 pm
trubador suggestion is good for interactive deletion.
For command line deletion, the following two lines, put in a program file, should do the trick.
%a = @wlookup("*", "alpha") delete {%a}
JhonnyCa
Postby JhonnyCa » Wed Feb 18, 2015 3:45 am
Thank you very much, it worked perfectly fine!
