DCCGARCH11
dnguyen1
Re: DCCGARCH11
Postby dnguyen1 » Tue Dec 30, 2014 12:22 pm
Thank you so much!
dnguyen1
Re: DCCGARCH11
Postby dnguyen1 » Fri Jan 02, 2015 4:45 pm
I have a question regrading the use of dccgarch11* add-in. The add-in stopped working for my eviews yesterday. It is said that the use of add-in has been expired. Could you please give me an advice how to continue using the add-in, please?
trubador
Did you use forum search?
Re: DCCGARCH11
Postby trubador » Mon Jan 05, 2015 1:39 am
Yes, the add-in was intended to be used until end of last year. I'll extend it for 2015, but you'll have to wait for EViews team to return from ASSA 2015 event.
jimi
Re: DCCGARCH11
Postby jimi » Fri Jan 09, 2015 1:07 pm
Oh! I have searched everywhere so as to contact the author. I used the add in for the first part of my research estimation and now am 'hooked' because i can't use it for the second part due end of this month, January.
I hope this add in gets restored soon. I'm aware the event ended Jan 5, 2015.
trubador
Re: DCCGARCH11
Postby trubador » Sat Jan 10, 2015 7:44 am
You can now download and use the add-in until the end of year.
wildee
Re: DCCGARCH11
Postby wildee » Tue Feb 17, 2015 12:25 pm
Is it possible to adapt the add-in to allow testing for structural breaks (making use of any of the proposed structural break methodologies )
Can someone tell me how to verify a structural break at a known date using this model and program
Aaron
trubador
Re: DCCGARCH11
Postby trubador » Tue Feb 17, 2015 1:25 pm
No, the add-in does not have any formal structural break test. You can, however, generate dummy variables and use them as exogenous variables for the mean and/or variance equation. And then you can interpret the significance of coefficient(s) to serve the purpose.
wildee
Re: DCCGARCH11
Postby wildee » Wed Feb 18, 2015 4:55 am
Thank you, that should be sufficient to verify a claim for higher correlation in the latter (post known break point) part of my series?
There is an endogenous dummy variable method that I am investigating and is shown in the line below, this is a different structural break method to those I have seen so far and would it be possible to perform this within the add-in? The attached file shows the transformation under this method.
Aaron
bvguizar
Re: DCCGARCH11
Postby bvguizar » Thu Feb 26, 2015 1:28 am
I am trying to use this add in while I'm offline but it doesn't let me. Do you have to be online to use it? It says it expired. Thank you
trubador
Re: DCCGARCH11
Postby trubador » Thu Feb 26, 2015 1:44 am
Either update or download and install it again.
bvguizar
Re: DCCGARCH11
Postby bvguizar » Thu Feb 26, 2015 12:53 pm
Thank you, I have a bit of a theoretical question. The conditional volatility residuals of the dcc model is the same as the variance?
trubador
Re: DCCGARCH11
Postby trubador » Sat Feb 28, 2015 2:10 pm
I think you are asking me if the conditional volatility estimated in the first step is a regular GARCH model. Yes, that is correct. You can find details on the mechanics of the estimated model in the references cited.
littleice
Re: DCCGARCH11
Postby littleice » Wed Mar 18, 2015 4:02 am
Dear trubador,
Can I use the GARCH-M model in added-in? I tried to put the conditional variance to the RHS of mean equation but failed.
Thanks!
trubador
Re: DCCGARCH11
Postby trubador » Wed Mar 18, 2015 5:25 am
Unfortunately no, you cannot do that.
Delia
Re: DCCGARCH11
Postby Delia » Tue Mar 31, 2015 3:20 am
Hi trubador. Can u offer an example which used dccgarch11? I don't know what should be put in four empty boxes. Thanks so much.
Return to “Add-in Support”
