VAR-GARCH
mollydokora
VAR-GARCH
Postby mollydokora » Wed Oct 01, 2014 1:09 pm
Hi everybody,
I'm currently working on my thesis and I should estimate the temporal volatility transmission across the crude oil market and different stock market sectors . I have the time series for oil and stock market indices logged from 1995 to 2013. I have EVIEWS 8.
I would like to ask if there is a way to build a bivariate VAR(1)-GARCH(1,1) model on EVIEWS: seems that the best software is RATS, but I have no idea how to use it.
I am replicating a study by Arouri, Jouini and Khuong 2012 and have no idea how to program this model in eviews.
Does anybody have an idea?
Thank you so much!
bvguizar
Re: VAR-GARCH
Postby bvguizar » Fri Dec 19, 2014 5:10 am
Did you get a reply about this? I am trying to do the same thing but for ethanol market.
trubador
Did you use forum search?
Re: VAR-GARCH
Postby trubador » Fri Dec 19, 2014 6:30 am
bvguizar
Re: VAR-GARCH
Postby bvguizar » Tue Dec 30, 2014 8:28 am
Dear Trubador,
How can you calculate spillover ratios using BEKK or DCC models?
trubador
Re: VAR-GARCH
Postby trubador » Wed Dec 31, 2014 2:42 am
bvguizar
Re: VAR-GARCH
Postby bvguizar » Fri Jan 02, 2015 9:30 am
Dear Trubador,
I went through the post you sent and I was wondering if the programming for spillover ratios can be done using three variables?
I have done the programming again but when I ran it I see many problems. Please find attached the program and the E-views file. Could you help me with this?
eviews_example garch model.WF1
Eviews File
(21.6 KiB) Downloaded 765 times
BV Garch in mean_Lowertriangle EVIEWS EXAMPLE for 3 variables.docx
Programming
(20.28 KiB) Downloaded 850 times
trubador
Re: VAR-GARCH
Postby trubador » Mon Jan 05, 2015 1:23 am
That code estimates a bivariate garch-in-mean model as the name suggests. You need to get rid of in-mean specifications and modify the rest of the code so as to represent a VAR-GARCH model. It may be tedious, but not difficult. Even if you establish the correct specification, you may still experience some convergence problems. In that case, please search the forum for similar discussions.
bvguizar
Re: VAR-GARCH
Postby bvguizar » Mon Jan 05, 2015 5:49 am
Dear Trubador,
I am new to programming. I'm not sure where to put a VAR-GARCH model in here?
However, I have checked other posts
http://forums.eviews.com/viewtopic.php? ... 964#p26964
http://forums.eviews.com/viewtopic.php?f=4&t=9476
I thought I have changed the bivariate model to put it in 3 variables. So, a mean equation is not needed in a VAR-GARCH model?
Could you help me please?
trubador
Re: VAR-GARCH
Postby trubador » Mon Jan 05, 2015 7:00 am
The issue here appears to be more demanding than your programming skills. Your task requires technical background regarding: i) Spillover effects, ii) VAR-GARCH models and iii) Maximum likelihood estimation.
You confuse "in-mean" concept with "mean equation". The first one refers to inclusion of conditional volatility in the mean equation. In your case, mean equations should look like a VAR(1) model and the MGARCH part should operate on the residuals from those equations. And since you are interested in spillover effects, diagonal specifications will not work for you.
bvguizar
Re: VAR-GARCH
Postby bvguizar » Mon Jan 05, 2015 7:06 am
I am sorry for the trouble, yes I do have issue with this since I just got started to familiarise in these GARCH models. I have calculated a VAR in Microfit and I am using the residuals of the VAR to calculate the spillover effects. I wasn't aware of the limitations using diagonal specifications. In theory I assumed that once you estimate the BEKK model, you calculate the conditional variance of steady state. In a BEKK model with 3 series, for example, you are estimating 6 equations (3 variances and 3 covariances). Then you assume that Ht=Ht-1 and episilon t-1=0 (you are in equilibrium). This is how you find h11, h22, h33, h12, h13, h23 of steady state (six equations & six unknowns). And finally you simulate a shock in one market that changes the conditional variance (of steady state) by 1% and see how this affects the variances in all markets over a period of time. Can this be done in Eviews?
trubador
Re: VAR-GARCH
Postby trubador » Tue Jan 06, 2015 2:53 am
It is doable, but you may need to put a lot more effort into it than you think.
