Hello everyone,
I am trying to replicate the estimation in one Article which is available at this link:
http://ssrn.com/abstract=2519503
The data for the Article was taken from the Chicagofed website:
https://www.chicagofed.org/banking/fina ... -bank-data
I need to take the complete data from 1976-2000 (which is quarterly and are in separate files for each quarter of each year for all banks of chicago) and extract observations only for two banks (entity value of 1st bank=128258 and of 2nd bank=403656), and then transform the data from quarterly to annual. It is very time consuming to do it one by one. I wonder is there any code or any program in eviews which can help me to do it easier?
Thanks in advance.
Chicagofed data import into eviews
Re: Chicagofed data import into eviews
I would do the downloading and unzipping in powershell, attached below some code which more or less does this with the CFTC data. The Eviews import can also be done dynamically by creating the import files dynamically (not done in the code below since I only have 3 fixed name excel sheets).
# COPY FILES WITH DYNAMIC NAMES FROM THE INTERNET
############ CFTC ################################
$userAgent="Mozilla/4.0 (compatible; MSIE 6.0; windows NT 5.2;)"
$wc = New-Object System.Net.WebClient
$wc.Headers.Add("user-agent",$userAgent)
$wc.Proxy.Credentials = [System.Net.CredentialCache]::DefaultNetworkCredentials
$coresource="http://www.cftc.gov"
$sourcepage="http://www.cftc.gov/MarketReports/CommitmentsofTraders/HistoricalCompressed/index.htm"
$webpagetxt = "C:\Database\ExternalSources\cftc.txt"
$webpage=$wc.DownloadString($sourcepage)
$webpage > "$webpagetxt"
$year_cur=get-date -Format yyyy
$year_cur_s=get-date -Format yy
$year_prev=$year_cur-1
$year_prev_s=$year_cur_s-1
$year_prev2=$year_cur-2
$year_prev2_s=$year_cur_s-2
$searchstring_cur="dea_fut_xls_"+$year_cur+".zip"
$searchstring_prev="dea_fut_xls_"+$year_prev+".zip"
$searchstring_cur_hist="deafut_xls_1986_"+$year_prev+".zip"
$searchstring_prev_hist="deafut_xls_1986_"+$year_prev2+".zip"
$cftc=Get-Content $webpagetxt | Select-String -pattern .*$searchstring_cur -Allmatches | % { $_.Matches | % { $_.Value } }
if(!$cftc)
$wc.DownloadFile("http://www.cftc.gov/files/dea/history/"+$searchstring_prev,"C:\Database\ExternalSources\cftc.zip")
$wc.DownloadFile("http://www.cftc.gov/files/dea/history/"+$searchstring_prev_hist,"C:\Database\ExternalSources\cftc_hist.zip")
$newname="\FUT04_"+$year_prev2_s+".xls"
else
$wc.DownloadFile("http://www.cftc.gov/files/dea/history/"+$searchstring_cur,"C:\Database\ExternalSources\cftc.zip")
$wc.DownloadFile("http://www.cftc.gov/files/dea/history/"+$searchstring_cur_hist,"C:\Database\ExternalSources\cftc_hist.zip")
$newname="\FUT04_"+$year_prev_s+".xls"
$destination="C:\Database\ExternalSources"
$source1="C:\Database\ExternalSources\cftc.zip"
$source2="C:\Database\ExternalSources\cftc_hist.zip"
$shell = new-object -com shell.application
New-Item -ItemType Directory -Force -Path $destination -WarningAction SilentlyContinue
$shell.namespace($destination).copyhere($shell.namespace("$source1").items())
$zip=$shell.NameSpace($source2)
foreach($item in $zip.items())
$shell.Namespace($destination).copyhere($item)
Rename-Item $destination\annual.xls cftc_current.xls
Rename-Item $destination\FUT86_03.xls cftc_early.xls
Rename-Item $destination$newname cftc_late.xls
& 'C:\Program Files\EViews 8\EViews8_x64.exe' "C:\Database\ext_import_cftc.prg"-
salahaddin
Thanks a lot for your help. The problem is I am trying your code in powershel and only last part of the code does not work and eviews gives an error: "C:\DATABASE\EXT_IMPORT_CFTC.PRG" not found on disk.
But all the data is downloaded normally.
I do not have any idea about programming. Could you please help me to download the same thing from chicagofed? I tried to change the website from cftc to chicagofed but now the code does not work at all. Could you please provide help with this specific data?
Thanks again,
regards,
Sam
Thanks again,
regards,
Sam
The above code is the best help I can provide, but just replace the website to the one of your interest and see if it works, the missing .prg file simply imports the excel data into eviews using the import command
salahaddin
I changed the website respectively but it did not work. I could manage to write a program which extracts data for only two banks. now the problem is to put those data together for respective banks. I will post my question in a different way.
Still thank you very much for trying to help.
Best wishes,
Sam
Best wishes,
Sam
