Is there a way to supress the Program Log so it is not the front window, or even better, a way to save (freeze) the Program log as an object within the workfile?
Regards
Martin
Program Log
Re: Program Log
Unfortunately not. This is a kludge but you could do the following:
1. create log window via a program
2. minimize it the log window by pressing the _ button at the top right of the window
3.Run your program
To answer the second part, at the end of your program you would have to save the log to a file and then append that file to a text object. For example
logmode all
statusline hello3.Run your program
logsave output.txt
textobject mytextobject
mytextobject.append(file) output.txtRe: Program Log
Works like a charm,
But is there no way to close the Program Log?
Regards
Martin
Regards
Martin
Re: Program Log
Unfortunately not
