Probit model_warning message on the equation output
Anne_Katy
Postby Anne_Katy » Sun Nov 16, 2014 4:48 am
Hi all,
I run a probit model (only with two regressors) and I get the following warning message on the equation output:
"WARNING: Singular covariance - coefficients are not unique
Covariance matrix computed using second derivatives
WARNING: Complete separation detected at estimated parameters (results
may not be valid)"
Why does this happen? which is the problem? Can someone help me?
Thanks in advance.
Anne
trubador
Did you use forum search?
Re: Probit model_warning message on the equation output
Postby trubador » Mon Nov 17, 2014 2:25 am
Hard to say without seeing the actual workfile. But the following discussion might be helpful: http://forums.eviews.com/viewtopic.php?f=4&t=4257
Postby EViews Glenn » Mon Nov 17, 2014 7:57 am
The manual has (what I hope is) a clear description of the meaning of this warning.
