i found this http://forums.eviews.com/viewtopic.php?f=15&t=301
yet my maths is not sufficient to modify the code for quarterly data, i am asking if some1 could post the solution for it. it must be quite easy, but i couldnt do it after reading the hylleberg article :S
HEGY test
Ingolstadt
HEGY test
Ingolstadt
Re: Hegy test
some mins later i found a better article :)
thats my code
is this correct? but i still need some help with the test statistic, because i have no clue what that code means :?
thats my code
call y
subroutine y
'generate auxiliary polynomials
series Z1 = y + y(-1) + y(-2) + y(-3)
series Z2 = - y + y(-1) - y(-2) + y(-3)
series Z3 = - y + y(-2)
series Z8 = y - y(-4)
'create seasonal dummies
for !i=1 to 3
series s!i = @seas(!i) - @seas(4)
'estimate the equation
equation eq1.ls(showopts,c=1e-5,m=1000) Z8 c s1 s2 s3 Z1(-1) Z2(-1) Z3(-1) Z3(-2) Z8(-1 to -4)
show eq1.output
'generate the test statistics that are not given in the equation output (Warning: critical values are different from those of EViews'. You should find true values for accurate hypothesis testing!)
freeze eq1.wald c(15)=0, c(16)=0
freeze eq1.wald c(17)=0, c(18)=0
freeze eq1.wald c(19)=0, c(20)=0
freeze eq1.wald c(21)=0, c(22)=0
freeze eq1.wald c(23)=0, c(24)=0
freeze eq1.wald c(14)=0, c(15)=0, c(16)=0, c(17)=0, c(18)=0, c(19)=0, c(20)=0, c(21)=0, c(22)=0, c(23)=0, c(24)=0
freeze eq1.wald c(13)=0, c(14)=0, c(15)=0, c(16)=0, c(17)=0, c(18)=0, c(19)=0, c(20)=0, c(21)=0, c(22)=0, c(23)=0, c(24)=0
'delete auxiliary series and seasonal dummies
delete z* s*
endsub
