Hello
I'm using arimasel command to forecast the X series. When using arimasel it shows optimal specification of ar, ma, sar, sma and during the window (it contains optimal specification) the equation named "_tempeq01" created but after the press ok button (optimal specification window) it automatically dissappeared. how to save this temporary equation? the reason i want to save this is to forecast the X series using optimal arima specification. So is there any other method to choose optimal specification. Forexample X.arimasel(maxar=3,maxma=3,sar=1,sma=1,diff=2,crit="aic")
!p=results(1) '''optimal specification of ar
!q=results(2) '''optimal specification of ma
!bigp=results(3) '''optimal specification of sar
!bigq=results(4) '''optimal specification of sma
equation forecast_eq.ls X c AR(1 to !p) MA(1 to !q) SAR(1 to !bigp) SMA(1 to !bigq)
(but running this code gives error that "results not defined in !p=results(1)" what is the correct one instead of results?
how to save tempoeq01(temporary equation) when using arimase
Re: how to save tempoeq01(temporary equation) when using ari
The last line of the add-in deletes the temporary equation. Remove that line.
sorry how should i delete the last line? please make it more clear.Thank you
Open up the program, scroll down to the last line of the program, then delete it, and save it.
thank you very much
