Writing out residuals into excel file
newbie001
Postby newbie001 » Fri Aug 22, 2014 12:07 pm
Hi, I am wondering how to extract residuals from multiple regressions. Right now I want to test out a series of independent variables and then look at the residuals from each regression. Currently I have
for %1 "x1" "x2"...
regress y {%1}
smpl %start %end
series {%1} = resids
excel_output.add {%1}
write(t=xls) excel_ouput
I have been running into many syntax errors and excel only recording one residual series. Any help would be greatly appreciated. Thanks!
Re: Writing out residuals into excel file
Postby EViews Gareth » Fri Aug 22, 2014 1:05 pm
group excel_output for %var "x1 x2 x3 x4" equation eq_{%var}.ls y {%var} eq_{%var}.makeresids resid_{%var} excel_output.add resid_{%var} next wfsave(t=excelxml) myfile.xlsx @keep excel_output
Superbakkz
Postby Superbakkz » Sat Oct 11, 2014 2:51 am
I would like something similar, only that i need to report the heteroskedastic robust standard errors. Instead of one dependent variable I also have multiple, each to be regressed on "their own" independent ones.
How would I adjust the code to make this work?
Thanks!
Postby EViews Gareth » Sat Oct 11, 2014 9:00 am
Could you provide more details on exactly what you're trying to do?
