Set "pre-defined" colors
jfoster4731
Postby jfoster4731 » Sat Sep 20, 2014 11:54 pm
I am writing a program to make a graph. E-views 8 has a set of predefined colors: blue, red, green, etc, and it is also possible to select colours using @RGB(#,#,#). Is there a way to use the @RGB command to set a predefined color? For example,
setcolor cyan @RGB(225,225,255)
Then I can just write "cyan" wherever I would like that colour.
Thank you
Re: Set "pre-defined" colors
Postby EViews Gareth » Sun Sep 21, 2014 7:58 am
There is not, no.
You might be better off using templates, if you're using the same colours a lot.
Postby EViews Gareth » Sun Sep 21, 2014 8:21 am
or, you could always do something like:
%cyan = "@RGB(225,225,255)"
and then use {%cyan} wherever @rgb is expected.
jfoster4731
Postby jfoster4731 » Sun Sep 21, 2014 4:18 pm
Thank you Gareth,
That works great.
