I have created a VBA script that uses the Eviews COM object and it runs fine on my machine. However, when another user tries to run it they get the error: User defined type not defined and the debugger highlights the Dim mgr as New Eviews.Manager line of the following snippet
Dim mgr As New EViews.Manager
Dim app As EViews.Application
Set app = mgr.GetApplication(ExistingOnly)I googled it and MS gives some suggestions regarding something called the DAO but after enabling that reference too the same error appears. Also MS seems to think this is a 2003 problem whereas we are using Excel 2010 and later versions. Any ideas would be greatly appreciated! Thank you in advance.
