Im using :eviews6:
And i wish to sum up a series
Any ideas?
How to sum up observation?
To sum up squares:Im using :eviews6:
And i wish to sum up the squares of a series
Any ideas?
series sum = @sumsq(x)
series sum = @sum(x)
Re: How to sum up observation?
thank you!
Did you want the squares or just the levels? @sumsq will give you the sum of squared values. @sum will give you the sum.
Can @sum be used to sum cross sections, as in to sum up states to get the US total?
You have to give more context. How is your workfile structured?
I am working with bilateral travel data,I think I could structure it as a panel, but I did not explicitly do this.
I have it set up as visit_i_j (visits from country i to country j), annual data.
I have generated a pool with the list of countries. So conceptually, I think it should be visit_?_? (will this work?) and when i=j it is zero.
I would like to be able to sum up totals inbound/outbound by year, for example:
total outbound from i = visit_i_?
total inbound to i = visit_?_i.
What would be best way to calculate totals by year? Something like:
smpl 2010 2010 (then loop through years?)
totalout_? = @sum(visit_i_?)
OR another design?
I suspect wit the bilateral aspect, this may be deeper than just the @sum command...
Thanks for guidance.
OR another design?
Maybe a combination of @sum and @rsum, having made the appropriate groups.
Try creating a new page and use the link object with match merge:
You have to create a new alpha series in the new page with the category identifiers you are interested in summing over.
Link NewLinSeries
NewLinkSeries.linkto(c=sum) oldpage\oldseries @src OldAlphaIdentifier @dest newAlphaIdentifierWho is online
