EXTRACTING TABLES FROM A SPOOL
molugbode
Postby molugbode » Sun Jul 05, 2009 8:02 am
I have written a series of programmes which runs a series of OLS regression models and transfers the output to a spool. However when I want to copy the tables to excel, I found that I could only copy and paste one table at a time. I have a lot of tables in the spool and was hoping if anyone knew of how I could copy all tables within the spool to an excel sheet at once. Also if this is not possible, is there anyother way of tackling this .
Many thanks in advance.
Re: EXTRACTING TABLES FROM A SPOOL
Postby EViews Gareth » Sun Jul 05, 2009 9:09 am
molugbode
Postby molugbode » Sun Jul 05, 2009 11:40 am
Many thanks for your suggestions.
I have tried both options:
output(r) c:\myrtffile.rtf 'redirect printing to a rtf file
' or
output(t) c:\mytextfile.txt 'redirect printing to a text file
print myspool
I keep getting the message" unable to open file in "print myspool" .
This is an abridged version of the programme I have used.
equation eq1.LS(N) AERO C INDVAR
equation eq2.LS(N) AUTO C INDVAR
equation eq3.LS(N) BEVERAGE C INDVAR
spool myspool
myspool.append eq1
myspool.append eq2
myspool.append eq3
Probably gone wrong at some point. Can you kindly proffer suggestions ?
molugbode
Postby molugbode » Mon Jul 06, 2009 4:36 am
Many thanks. Sorted it out now.
