SPOOL
lpluser
SPOOL
Postby lpluser » Thu Jul 02, 2009 7:13 pm
I m a very new Eviews user and have seen questions elsewhere on this board that suggest using SPOOL function to print to in order to capture a series of regression model outputs.
could someone provide a sample of how to do this using SPOOL and printing to SPOOL
Re: SPOOL
Postby EViews Gareth » Thu Jul 02, 2009 7:47 pm
create u 100 series y=nrnd series x1=nrnd series x2=nrnd equation e1.ls y c x1 equation e2.ls y c x2 spool myspool myspool.append e1 myspool.append e2
Re: SPOOL
Postby startz » Thu Jul 02, 2009 7:56 pm
Or, after having created mySpool, redirect desired output in the Print dialog.
lpluser
Re: SPOOL
Postby lpluser » Fri Jul 03, 2009 9:07 am
Thank you.
Can I redirect within the programing environment, or can I only do that via the dialog
Re: SPOOL
Postby startz » Fri Jul 03, 2009 9:38 am
Gareth's example effectively does that. In addition, you might want to look at the Output command in the help system.
lpluser
Re: SPOOL
Postby lpluser » Fri Jul 03, 2009 11:57 am
wonderful..thanks to you both
