In a model a regressed I used a dummy variable at the left-hand side to explain its presence. The explanatory variables at the right hand side are partly significant, but how do I interpret the coefficients.
For example: Y= b + 24.5 population + e
So one of the coefficients has a result of 0.245 for population. Is it possible to interpret it as: An increase of one unit of population causes an increase of 24.5% of the dummy variable. Or is it not possible and should it be interpreted differently. Or dummy variable is explained by population for 24.5% ?
Thank you in advance!
Interpreting results with a dummy at left hand side
Re: Interpreting results with a dummy at left hand side
Google "linear probability model"
Carlo Lazzaro
I'm not clear with your approach if your regresion setting is the linear one.
Conversely, if you are talking about a logistic regression a yes/no dependent variable makes sense. However, the interpretation of your results could be easier if you convert the dependent variable into an odds ratio.
Kind regards,
Carlo
Kind regards,
Carlo
Thanks everyone for your help!
