Dear all,
I am trying to do a rolling window for variance ratio test, and I read a lot of programming topics and I reached to following codes but it doesn't work, I got NA in all metrics, why??
I want to do rolling for MVR but with wildbootstrap probabilities, so my problem here is about test specification, Here you are codes, please help me clarify what is the problem
!width = 20
!lastfirst = @obsrange-!width+1
matrix(!lastfirst, 2) vratio
!doprob=0
!probchoice=0
!result =0
%problist ="default wildbootstrap"
%probOpt =""
!result = @uidialog("check",!doprob, "View prob options?")
if !result=-1 then 'if user cancelled, then stop program
stop
endif
if !doprob =1 then
!result = @uilist(!probChoice, "test specification probabilities ", %problist) ' put up prob dialog
stop
endif
if !probChoice = 2 then
%proOpt = "prob=wildbootstrap"
endif
endif
for !i=1 to !lastfirst
smpl @first+!i-1 @first+!i-1+!width-1
freeze(bb) R.vratio {%probOpt} 2 4 8 16
vratio(!i, 1) = @val(bb(11, 3))
vratio(!i, 2) = @val(bb(11, 5))
if (@isobject("bb")) then
delete bb
endif
urgent please, rolling window
Re: urgent please, rolling window
We'd need the workfile, I think.
Sara Elsayed
Thanks for your reply.
here you are the work-file, and the variable to be used here is called r_efgi, instad of just R in the codes below.
Can I have also another questions,
1- If I need to use window width of 260 and to move 4 observation each time not one observation, how can I change the codes?
I can't understand how to get the proper number of sub-samples or window that related to my observation number, I read papers use 260, so is it okay to use it or it depends on my observation?!
2- How can I plot the p-values of each test against the last time points of moving sub-samples windows? because i want to see how efficiency(RW hypothesis) improve through time.
I would be glad if you can help me as I have short time constrains
- efgi.wf1
- (51.32 KiB) Downloaded 190 times
The line:
should be:
And the line:
Should be:
freeze(bb) R_efgi.vratio {%probOpt} 2 4 8 16
freeze(bb) R_efgi.vratio({%probOpt}) 2 4 8 16
%proOpt = "probcalc=wildboot"
Sara Elsayed
However, For this command
freeze(bb) R_efgi.vratio ({%probOpt }) 2 4 8 16
I got error message of illegal specification
You have a space.
Sara Elsayed
Unfortunately, I got the same final result NA in both columns.
I tried theses codes instead
!width =260
freeze(aa) r_msci.vratio(probcalc=wildboot, btreps=10000) 2 4 8 16
vratio(!i, 1) = @val(aa(11, 3))
vratio(!i, 2) = @val(aa(11, 5))
if (@isobject("aa")) then
delete aa
endif
It seems it works, but I feel that there is something wrong, because when I compare p-values which changes only after 3 digit after dot like this (0.0002), to plots of graph of old paper which can reach far to 0.6, I could not get the same result. I don't know what is the problem?! Is it in my codes? again I am testing joint VR with wildbootstraping with hetero
if I want to step by 4 observation
Can I just change this command ?
smpl @first+!i-1 @first+!i-1+!width-4
!width =260
delete aa
endif
Sara Elsayed
please, Can I have another column in the matrix that includes the end point to each sub-sample rolled as I must plot the p-values through time, please can you help me?
