Fama-MacBeth regression
metrix
Re: Fama-MacBeth regression
Postby metrix » Mon Jul 28, 2014 9:33 am
I thought that this line
equation {%subcsavg}.ls(cov=hac) avgrets c betag
I have change it by this code (Ref: EViews 8 command ref pp 382 Panel LS Options)
equation {%subcsavg}.ls(wgt=cxsur) avgrets c betag
but an error message appear.
I don't know what to say :| thanks for the help.
Postby EViews Gareth » Mon Jul 28, 2014 10:01 am
You don't have a panel.
metrix
Postby metrix » Mon Jul 28, 2014 10:19 am
no idea :oops: , can you help me.
Postby EViews Gareth » Mon Jul 28, 2014 10:31 am
Looks like the subroutine FMB is the part that does the calculations. The line:
rowplace(g, @transpose(@inverse(@transpose(design) * design) * @transpose(design) * retvec), j)
is the one that performs OLS and puts the row of coefficients into the matrix g. Just change that line to do whatever calculation you want, instead of OLS.
metrix
Postby metrix » Fri Aug 01, 2014 2:14 pm
thanks for your help Mr Gareth.
mick1987
Postby mick1987 » Sun Aug 03, 2014 12:01 pm
Hi, I would like some tips on how to modify the fama-macbeth code such that I also get the R squared of the regression. Thanks in advance!
Postby EViews Gareth » Sun Aug 03, 2014 2:18 pm
Which regression?
mick1987
Postby mick1987 » Mon Aug 04, 2014 12:35 am
The second regression where the cross-sectional regression is done.
Postby EViews Gareth » Mon Aug 04, 2014 4:23 am
It isn't currently covered by the add-in. As mentioned a few posts above, there is a single subroutine that currently performs the least squares regression (and does so using matrix objects rather than the built-in estimation routines). You would have to modify that subroutine to also calculate, and store, the R-squared.
mick1987
Postby mick1987 » Mon Aug 04, 2014 5:42 am
Thanks. I have tried to understand how the rolling add-in function in eviews works and also tried to implement it. Do you think I can apply the same method as in the roll code for the add-in?
mick1987
Postby mick1987 » Mon Aug 04, 2014 5:53 am
Sorry for the diffusing question.. what I'm asking about is that the roll add-in function reports the r squares.. can I use their way to get the r square incorporated into the fama-macbeth add-in??
mick1987
Postby mick1987 » Mon Aug 04, 2014 5:57 am
Also I have a question regarding the second table output from the add-in function, are the betas reported in table 2 average betas from the first regression?
Maverick
Postby Maverick » Mon Aug 04, 2014 8:53 am
Hi, I also need to incorporate r square into the code. I understand the first part of the fmb subprogram, but not the following part of the operation in the program:
@transpose(@inverse(@transpose(design) * design) _
If someone can help me understand this part it would be really appreciated! Thanks in advance! Also I would like to know if this sign: _ has a meaning in the code?
Maverick
Postby Maverick » Mon Aug 04, 2014 8:58 am
Also it would be nice to understand the purpose of design=1 in the below code?
matrix(n_p, n_f + 1) design = 1
EViews Rebecca
Postby EViews Rebecca » Mon Aug 04, 2014 9:30 am
They are betas from a second regression that use the betas from the first timeseries regression as regressors. See equation 4 in the documentation for more details.
Return to “Add-in Support”
