How to find optimal breakpoint in Segmented (piecewise)?
goldman1804
Postby goldman1804 » Wed Jul 23, 2014 9:10 am
I have an x and y variable who seem to be strongly linked until my x variable goes above a certain number, where the relationship breaks down (a breakpoint), and a new relationship begins (curve is much less steep). Is it possible to find the optimal breakpoint using EViews? And if so how would I go about doing it.
Thanks!
Re: How to find optimal breakpoint in Segmented (piecewise)?
Postby EViews Gareth » Wed Jul 23, 2014 10:23 am
There are many breakpoint tests, and some breakpoint estimation techniques in EViews 8. Probably the best place to start is to look up "breakpoint" in the User Guide index.
goldman1804
Postby goldman1804 » Thu Jul 24, 2014 12:54 am
When using the Quant-Andrews test when it asks what variables do you wish to vary across the breakpoint - what is the effect of using your x variable and a constant vs just your x variable? It seems to change the result substantially, but I cant figure out which one is correct
Postby EViews Glenn » Thu Jul 24, 2014 7:35 am
The latter constrains the intercept to be the same across regimes.
