how to forecast with markov regime switch model?
tanghanpost
Postby tanghanpost » Tue Jul 15, 2014 1:43 am
I am using the data which provided by eviews 8-GNP_hamilton,i create a markov regime switch model, I changed the eqation by dynamic: g c g(-1), the non-switching regressors still are-ar(1) ar(2) ar(3) ar(4), and i chosed the "regime specific error variances", after the estimation, I want to forecast the dependent variable-g, but forecast has teld me that " the SIGMA is not defined". I don't know what wrong with the equation?
Another,
I fined that the forecast dialog is-"SIGMAf" not the variable i want-the dependent variable "gf", then how to use the markov switch model to forecast the dependent variable?
Thank you for spending time to answer me.
Tanghan
gnp_hamilton.wf1
(38.49 KiB) Downloaded 474 times
Re: how to forecast with markov regime switch model?
Postby EViews Glenn » Tue Jul 15, 2014 2:52 am
What's the date on your copy of EViews?
tanghanpost
Postby tanghanpost » Tue Jul 15, 2014 6:54 am
Sorry, I don't know the date,
But does it important to the model?
may i change the date, can solve this?
Postby EViews Glenn » Thu Jul 17, 2014 6:33 am
Select Help/About EViews from your main menu. I believe that this is related to a bug that was fixed some time ago, and wanted to double check that your copy was prior to the fix. Alternately, use Help/Update to update your copy of EViews to the latest shipping version.
tanghanpost
Postby tanghanpost » Fri Jul 18, 2014 6:22 pm
Thanks for your help.
Do you mean the date of Eviews 8 is -Standard Edition - Jul 2 2014 build?
I had update Eviews to the latest, but the problem still .
Postby EViews Glenn » Sat Jul 19, 2014 8:17 am
Okay, I'll take a look. I just thought of one thing. Can you please reestimate your equation by clicking on the estimate button and then try again? Thanks.
