CGARCH
bubu
CGARCH
Postby bubu » Sun Jun 28, 2009 6:04 am
hej hej
i would be really grateful in case somebody can help me with some hints about how can I plot the long run component and the short run component of a CGARCH.
Thank u all
trubador
Did you use forum search?
Re: CGARCH
Postby trubador » Sun Jun 28, 2009 9:22 am
Once you estimate the CGARCH model, you can save conditional variance and permanent (or long run) component via clicking "Proc/Make GARCH Variance Series". Short run component is simply the difference between conditional variance and the permanent component.
bubu
Re: CGARCH
Postby bubu » Sun Jun 28, 2009 9:52 am
thanks a lot trubador, I succeed to make the conditional variance series, but I do not know how to do the permanent component :(
trubador
Re: CGARCH
Postby trubador » Sun Jun 28, 2009 1:40 pm
Unless you enter a name for the "Permanent Component" box, it will not save the series. Please see the picture attached.
Saving the permanent (long run) component series in CGARCH modeling
bubu
Re: CGARCH
Postby bubu » Sun Jun 28, 2009 11:43 pm
unfortunatelly i do not have this screen when select "Make garch variance"...i think it's because of Eviews, I'm using Eviews 5.
Lots of thanks for u help.
bubu
Re: CGARCH
Postby bubu » Mon Jun 29, 2009 12:27 pm
trubador pls I need you help in this,
I'm analysing the volatility with 4 garch models and then VECM for long run relations between markets. What i do not understand is the connection between the first part of the article and the second part, I mean I should introduce the short run relations from CGARCH in VEC...or how else I can make connections between these?
Thank you for you time and u'r extreme helpful answers
trubador
Re: CGARCH
Postby trubador » Mon Jun 29, 2009 2:00 pm
Could you please cite the article you mention?
bubu
Re: CGARCH
Postby bubu » Mon Jun 29, 2009 2:06 pm
I think I manage to attached the file. The name of the article is
"Volatility and Long Term Relations in
Equity Markets: Empirical Evidence
from Germany, Switzerland, and the UK"
by Guidi, Francesco.
thank you so much for your support
volatility and long term relations.pdf
(1.15 MiB) Downloaded 1012 times
trubador
Re: CGARCH
Postby trubador » Mon Jun 29, 2009 2:46 pm
It seems two parts are actually independent of each other empirically. Author preferred to analyse the volatility in markets in a univariate (but detailed) framework unlike the returns, where he built a vector error correction model. Of course, a multivariate GARCH analysis would also be helpful in analysing the interaction between the markets (simultaneously in terms of returns and conditional variances), author followed a more complementary approach and decided to analyse the relationship between returns in a longer term framework. So everything seems fine...
bubu
Re: CGARCH
Postby bubu » Mon Jun 29, 2009 3:06 pm
thank a lot for everything, it helps a lot
do u think makes sense to introduce the long-run component of CGARCH in VECM?
trubador
Re: CGARCH
Postby trubador » Mon Jun 29, 2009 11:41 pm
Joint estimation of conditional variances and returns in a multivariate framework will be better. As long as you are aware of the fact that you are following a two-step approach, it will not be a problem. You should take into account this difference when interpereting your results.
bubu
Re: CGARCH
Postby bubu » Tue Jun 30, 2009 11:30 pm
Lots of thanks for your help trubador
