Constant multiplication
manowar
Postby manowar » Wed May 21, 2014 11:26 am
I am trying to run several regressions to determine the changes in the dependent variable when I alter the constant and independent variables. The regression in its unaltered original form is:
p c l k
Where p is output, c is the constant or intercept, l is labor and k is capital. I have no problem altering the independent variables by multiplying them (say by 500), but when I try to multiply c I get:
illegal lag or index specification for coefficient C
Is there any way to do this?
Re: Constant multiplication
Postby EViews Glenn » Wed May 21, 2014 11:46 am
You have to create a new variable
series cc = 500 equation eq1.ls p cc l k
manowar
Postby manowar » Wed May 21, 2014 3:20 pm
All you've done there is create a new variable whose value for each observation is 500, you didn't multiply the existing constant by anything. I want to multiply each of the observations of my constant by 500.
Postby startz » Wed May 21, 2014 8:42 pm
What do you think the observation is for a constant?
manowar
Postby manowar » Wed May 21, 2014 9:17 pm
Not sure I understand your question, but you do know that the constant is made up of more than one value?
The observations of my constant already have values, I don't need a new constant whose value for each observation is 500, I want to modify the values/observations of my existing constant by multiplying them.
Postby startz » Thu May 22, 2014 6:29 am
Using "c" in a regression is exactly the same as entering a variable that equals 1.0 for every observation. For that reason, Glenn's answer is correct. But then, Glenn's answers are almost always correct.
Postby EViews Glenn » Thu May 22, 2014 8:38 am
I don't know about that. Given the last couple of posts, it's clear that I didn't understand the original question.
manowar
Postby manowar » Thu May 22, 2014 9:04 am
Got it, thanks.
