Please can you tell me how to replace the Actuals with the Baseline data? I have a ragged edge dataset, and want to perform a Fit solution up to the latest point in the dataset, so I need to fill in the actuals series with forecast values for the missing observations.
Thank you!
Replace 'actuals' with 'baseline'
Re: Replace 'actuals' with 'baseline'
Are the missings in the series only for periods beyond the latest point? Are you sure you want to modify the actuals, or do you want to splice the actuals and the forecasts into a new series?
HollEviews
In my 'actuals' I have several data series, with end points between 2010 and 2013. I want to be able to run a "Fit" solution to 2013, so I need to fill in the missing values between 2010 and 2013 somehow. I don't particularly want to overwrite my actuals data, but is there a way to use the baseline output (which fills the 2010-13 values with equation projections) to run the Fit solution? As a temporary solution I've saved to a separate workfile, deleted all of my actuals, and renamed the _0 series as the actual names. That works okay, but I was hoping there was a slightly neater method. Many thanks for any suggestions!
Are the series that you want to fill the exogenous variables? And I'm still need to know whether the only missings are after the endpoints. And is there a reason you want to use the fit rather than another scenario?
HollEviews
All the variables in my model are endogenous. And yes, the missing values are only after the endpoint of each series. I'm using the Fit solution, because I want to assess the historical errors on each equation, so that I can set the add factors for the forecast after 2013. (which I'll run as a dynamic solution).
y = @recode(y=na, y_0, y)-
HollEviews
Many thanks!!
