How to set complex condition in EViews?
banhbengconuong
Postby banhbengconuong » Sat May 10, 2014 4:28 am
Dear Eviews experts,
I would like to make a complex condition for the lag of model. Suppose based on SIC criteria, number of lag is "a"
Below is my set of conditions:
if a <3 is true then a=3, else a = a
if a>6 is true then a=6, else a=a
At this moment I am stuck with setting the two conditions by writing 2 separate conditions because a is always either 3 or 6.
Please help me to fix it. Thank you very much!!!!
Re: How to set complex condition in EViews?
Postby EViews Glenn » Sat May 10, 2014 7:50 am
a = min(max(a, 3), 6)
banhbengconuong
Postby banhbengconuong » Sun May 11, 2014 2:15 am
I am sorry that when I write:
scalar a=min(max(1, 3), 6)
EViews says "Syntax error". Could you pls check that?
Many thanks
Postby EViews Glenn » Mon May 12, 2014 7:18 am
Sorry, use @min and @max.
banhbengconuong
Postby banhbengconuong » Mon May 12, 2014 8:24 am
Sorry again, EViews said "too many arguments" even if I choose only scalar a=@min(3,6) for instance.
Postby startz » Mon May 12, 2014 8:38 am
Try
a = (a<3)*3 +(a>=3)*a a = (a>6)*6 + (a<=6)*a
Postby EViews Glenn » Mon May 12, 2014 12:11 pm
Sorry, I'm thinking in different programming language syntax. To do Startz's excellent suggestion in one line
a = (a<3)*3 + (a>6)*6 + (a>=3 and a<=6)*a
