Hello everybody
I'm experiencing some difficulties in interpreting the output of the Johansen test for a set of 7 macroeconomic variables.
No problem with the interpretation of Trace and Max statistics, in this case the test detects the existence of 2 cointegrating equations.
Now I want to write out every single value of cointegrating coefficients. But how can I achieve this if, when looking at the 6th panel (the case with 2 coint. equations), the program automatically adjusts some of the coefficients to zero ??? As more cointegrating relationships are hypothesized, as more "strange" 0 and 1 coefficients appear.
I need clarification on this normalization process.
Thank you in advance :)
Johansen output - Help
- Johansen OUTPUT.pdf
- output of the Johansen test (7 macro variables)
- (68.66 KiB) Downloaded 234 times
Re: Johansen output - Help
can anyone help please ?
how can I get a table like this ?
as you can see from the Johansen output I previously uploaded, my variables are USDEUR, MUSA, MEUR, YUSA, YEUR, IUSA, IEUR
maybe should i take into account the unrestricted cointegrating coefficients and divide them by the first of the row in order to "normalize" them on the exchange rate ?
In the paper from which I took the image (Moosa, 1994), they don't talk about a normalization, so maybe they worked on the unrestricted coefficients ?
My target is getting a table like "TABLE 4". How can I do ??
Thanks in advance.
Thanks in advance.
