saving bandwidth using long-run variance estimation
styx
Postby styx » Thu Apr 24, 2014 8:22 am
I would like to save in a loop the automatic bandwidth selection that can be obtained using the lrvar command. The problem is that if I freeze the output I see the estimated bandwidth only in the header. Could you help me?
Thanks a lot.
Kind regards,
Peter
Re: saving bandwidth using long-run variance estimation
Postby EViews Glenn » Thu Apr 24, 2014 11:10 am
To be honest, it wasn't something that we anticipated people wanting to do so it's not possible at the moment. I've got an idea on how to make it accessible to users, but it'll need to go through a bit of testing.
styx
Postby styx » Sun Apr 27, 2014 1:45 am
Dear Glenn,
When do you think it'll be available?
Thanks,
Peter
Postby EViews Glenn » Sun Apr 27, 2014 9:04 am
Adding something like this mid-release is not something that we normally do so no promises, but we're thinking about it. If it's going to happen it'll be soon.
styx
Postby styx » Mon Apr 28, 2014 6:53 am
I'd appreciate it very much if it could be solved soon.
Thanks a lot.
Postby EViews Glenn » Mon Apr 28, 2014 12:43 pm
We've added a @title data member for the table object that will return the title string from the table, as in "string f = tab1.@title". You could then manipulate the string to grab the value of the bandwidth. It'll go out in the next patch (I don't know for when that is scheduled, but if it doesn't show up soon, I'll double-check on it).
styx
Postby styx » Tue Apr 29, 2014 1:28 pm
Dear Glenn,
It's very kind of you, thank you very much!
Kind regards,
Peter
styx
Postby styx » Fri May 02, 2014 12:52 am
Dear Glenn,
Unfortunately, this new title function has not yet been available. Can you please let me know when the new patch will be released?
Thanks a lot.
Kind regards,
Peter
Postby EViews Glenn » Fri May 02, 2014 9:47 am
I'll see if we can get one out today.
[edit] Sorry for the delay, but I'm told the patch will go out on Monday. Thanks for your patience.
styx
Postby styx » Tue May 06, 2014 12:27 am
Dear Glenn,
Thank you very much, it works perfectly.
Kind regards,
Peter
Postby EViews Glenn » Tue May 06, 2014 12:33 pm
Great. Glad it works for you.
