How do I find coefficients/equations from cointegration test
kjd31
Postby kjd31 » Mon Apr 21, 2014 12:57 pm
When I run the Johansen Cointegration test where can I see the true coefficients for each variable? The coefficients I see now don't make sense (i.e. are negative when the relationship is clearly positive, and in a normal regression the coefficients are positive). I've determined the two series are cointegrated, and now where can I see what the true coefficients (alpha and beta) are in the cointegration output?
Thanks.
kjd31
Re: How do I find coefficients/equations from cointegration
Postby kjd31 » Tue Apr 22, 2014 8:24 am
bump?
Postby EViews Glenn » Tue Apr 22, 2014 10:58 am
Make a VAR object from the group and estimate a VEC.
