I have modified the example rolling regression programs to work as a recursive FMOLS estimation storing the recursive coefficient estimates. Everything works fine. However, in addition to storing the coefficients I would need to get the residual standard error for each recursive estimation. How could I do that?
Many thanks in advance (the current program is shown below, I use Eviews7).
' get size of workfile
!length = @obsrange
' set window size
!window = 32
' set step size
!step = 1
' declare equation for estimation
equation eq1
' calculate number of rolls
!nrolls = @round((!length-!window+1)/!step)
' matrix to store coefficient estimates
matrix(2,!nrolls) coefmat ' where 2 is the number of coefficients
' variable keeping track of how many rolls we've done
!j=0
' move sample !step obs at a time
!j=!j+1
' set sample to estimation period
smpl @first @first+!i+!window-2
' estimate equation
eq1.cointreg(method=fmols, trend=const, regtend=none, lag=a, info=sic, kern=Bart,bw=andrews) p di
' store coefficients
colplace(coefmat,eq1.@coefs,!j)
show coefmat
Storing residual standard errors in a recursive regression
ylijohtaja
Re: Storing residual standard errors in a recursive regressi
!length = @obsrange
' set window size
!window = 32
' set step size
!step = 1
equation eq1
'vector to store ses
vector(!nrolls) sevec
!j=0
!j=!j+1
' estimate equation
'store se
sevec(!j) = eq1.@se
show coefmat
ylijohtaja
Many thanks Gareth,
There is one remaining problem: the 'sevec' vector contains only nulls except for the last period.
That's because I put it outside the Next by mistake. Move it inside the loop.
In this rolling regression program how can I store the standard errors., Also I am using Eview 5 version does it work fine with Sevec command?
'run rolling regression
equation eq1
'matrix to store coefficient estimates
matrix(6,120) coefmat ' where 3 is the number of coefficients
'variable keeping track of how many rolls we've done
!j=0
for !i = 1 to 120
!j=!j+1
smpl 1969Q1+!j 1984Q1+!j
' estimate equation - where the equation is y=c(1) + c(2)*x1 + c(3)*x2
eq1.ls PCE_COREAR PCE_COREAR(-1) PCE_COREAR(-2) PCE_COREAR(-3) UNEMPGAP(-1) INFEXP(-1) IMP_PCECOREAR(-1)
'store coefficients
'store se
sevec(!j) = eq1.@se
show coefmat
equation eq1
!j=0
for !i = 1 to 120
!j=!j+1
'store coefficients
'store se
sevec(!j) = eq1.@se
show coefmat
Note that your equation doesn't have an intercept.
Have you looked in SEVEC after you ran the program?
My program is not recognizing sevec, sorry I didn't define it. But not sure how to define it.
vector(120) sevecWho is online
