Dear All,
I recently re-installed EViews 8 (MAR 17 BUILD) on a laptop and I cannot now run previous programs which contain use of the .x13 routines. They work on older work pcs at my workplace which have not been updated (indeed they are running a july 2013 build, but a home p.c. running a more recent build has the routines working fine).
Attached are a sample of the series which I have verified to be transformed on the older (work pc) that give a non-descriptive error message on my recent re-install.
Any help or advice on this situation would be greatly appreciated.
Best wishes as always,
Charlie
X13 BUG
CharlieEVIEWS
X13 BUG
- x13bug.WF1
- (10.87 KiB) Downloaded 349 times
Re: X13 BUG
What options are you using?
CharlieEVIEWS
Re: X13 BUG
In the program it was using .x13(tf=auto), but Ive also tried it with just the standard .x13 command and neither appear to work on the re-install, but do on the earlier machines.
Re: X13 BUG
Works for me on my machine (also Mar 17th). Perhaps EViews didn't install correctly.
CharlieEVIEWS
Re: X13 BUG
A fresh re-install has not rectified the problem: Do I need to re-install any of the .x13 components separately or will they get refreshed automatically through the main eviews re-install?
Re: X13 BUG
They will be installed automatically.
Try creating a new, monthly, workfile and generating a random series. Can you run X13 on that?
CharlieEVIEWS
Re: X13 BUG
Hi Gareth (and thanks for your help with this),
The below code generates the same error:
The output is:
wfcreate m 1900 2000
genr strangebug = nrnd
strangebug.x13(tf=auto)
******Input Spec File******
1. series{
2. title = "STRANGEBUG"
3. start = 1900.1
4. modelspan = (1900.01, 2000.12)
5. name = "STRANGEBUG"
6. file = "C:\Users\<USERNAME>\AppData\ev_temp\EVX13TMP.DAT"
7. decimals = 1
8. }
9. transform{
10. function = auto
11. }
12. x11{
13. save = (d11)
14. }
CharlieEVIEWS
Re: X13 BUG
Dear all,
The problem was that the new username had a space in it which the subroutine doesnt like when calls the AppData folder
Hope this prevents any further confusion.
Charlie
Charlie
