Dear Sir/Madam,
which is the command for import data from a file.csv that has the character | as delimeter? If I import the data manually, from file-import-import from file, I have no problem, but if I try from a program it doesn't work.
For example:
import(custom=|) c:\test.csv @freq u 1
eviews doesn't consider the delimiter.
thanks
import data with the delimiter |
Re: import data with the delimiter |
Probably:
import c:\test.csv custom="|" @freq u 1
Yes, also without quotes --> import c:\test.csv custom="|" @freq u 1
thanks a lot
thanks a lot
Hey there! And what if I have two different 'custom' delimiters: "T" (yes, the letter "T"), and ":"? HTML/JSON files...
Tks for any help. Best, Fabio
I think you're out of luck.
