I have very short and easy question about makeresids command, especially for VAR object.
When I control the sample, for example,
smpl if w < 1
I construct a VAR object following:
var v01.ls 1 1 a b c @ w
Assume there are 100 observations satisfying that condition.
Additionally, I control the sample other way, for example,
smpl if w > 1
var v02.ls 1 1 a b c @ w
I wish to make residuals each way and merge it. So I used makeresids command.
In short, I typed at program window this way.
smpl if w < 1
v01.makeresids a1 b1 c1
smpl if w > 1
v02.makeresids a2 b2 c2
The problem is, although the condition is alternative, the residual series overlaps.
(When I did it by click, it works well, the series does not overlap)
As I should use program command because 'for loop' also should be used.
Short and easy question about "makeresids"
malyang713
Re: Short and easy question about "makeresids"
Seems to work just fine:
create u 1000
rndseed 1
series a=nrnd
series b=nrnd
series cc=nrnd
series w = nrnd+1
smpl if w < 1
smpl if w > 1
smpl @all
show a1 a2
malyang713
Thank you Gareth,
I see the problem is because of rewrite. I appended 'delete' command and it works well.
Thank to you again!
Thank to you again!
