Hey all,
I've got a quick question. I've been through the user manuals but haven't found an answer
to my simple problem.
Basically, I want to multiply a series in my active workfile with another series in a different
page/tab from my workfile. What is the best way of doing this without copying the series to
the active page?
Multiplying series from different pages/tabs
Re: Multiplying series from different pages/tabs
series a = page2\b * e
thanks, but any reason why that wouldn't work? I get an error message effectively saying:
page2\b is not defined in "series a = page2\b * e"
I've checked the syntax, the page name, the series I'm referring and am pretty sure it is correct...
Also, I've been having a hard time saving a series to an excel file. I've tried using something like
"a.write(t=xls) path" but that doesn't seem to work (i've figured out how to save graphs and tables tho!).
I know these are basic questions, but I only started using e-views a couple of days ago! I've got all the
books but it's not entirely clear where to find what you are looking for sometimes!
Which version of EViews?
Can't be done in 7.
That seems somewhat deficient!
I'm actually using e-views 7.1. Is there an add-on I can install to give
e-views 7.1 this functionality?
[Edit: I'm assuming you are referring to the page functionality, what about saving a series to an excel file in e-views 7?
Can you post the syntax for that? Thx]
OK - well, that sucks.
Going to have to rethink the structure of the code I want to write.
Did you see my edit on the above post?
ah ok. I saw wfsave when looking through the command reference manual but didn't realise it
could save in other formats besides .prg
thanks for the help Gareth.
