X11 & 64-bit Compatibility
robert downes
Postby robert downes » Fri Jan 31, 2014 6:07 pm
Our work just upgraded to EViews8 from Eviews5.
We have workfiles with the census X11 seasonal transformation being called, with no issues until today. After upgrading the following message occurs:
"X11, as provided by the U.S. Census, is not supported on 64-bit operating systems. Please use X12 instead in......"
I don't see any mention online or this forum regarding 64-bit and X11. Any help would be appreciated. Thanks in advance.
Re: X11 & 64-bit Compatibility
Postby EViews Gareth » Fri Jan 31, 2014 6:23 pm
There is nothing to add. X11 was written 45 years ago. It is not 64bit compatible.
robert downes
Postby robert downes » Fri Jan 31, 2014 6:56 pm
I don't understand how X11 was 64-bit compatible before, but not now. The CPU hasn't changed, only the version of EViews.
Thanks for the quick reply.
Postby EViews Gareth » Fri Jan 31, 2014 7:06 pm
I assume you upgraded the version of Windows too. It has nothing to do with the version of EViews. It is all about the version of Windows. X-11 won't run on 64bit Windows.
robert downes
Postby robert downes » Mon Feb 03, 2014 12:19 pm
Thanks EViews Gareth.......
Do you see any potential issues with running the 32-bit version of EViews with 64-bit Win7?
Postby EViews Gareth » Mon Feb 03, 2014 12:33 pm
No, other than the fact that X-11 won't work.
robert downes
Postby robert downes » Thu Feb 06, 2014 4:07 pm
Now a related question - can .x12 function be saved to an existing series that doesn't have an EViews specified extension?
I can run kunrtu.x12 but don't know how to save adjustments without EViews adding _sa to a new series
E.G.: previously the code we used for seasonal adjustments: x11(m) kunrtu kunrt -> this performed a seasonal adjusted on kunrtu with results saved in the series kunrt. Using kunrt as the "base name" still adds the _sa extension onto the series.
Now, I need to save seasonal adjustment for kunrtu.x12 as kunrt. I can't rename kunrtu_sa as kunrt because it already exists
Also, there are numerous series that this applies to, so using wildcards (*_sa) would be best if at all possible. Each variable being seasonally adjusted has 'u' as its last letter, so a wildcard such as *u_sa should catch all of the adjustment.
Postby EViews Gareth » Thu Feb 06, 2014 4:50 pm
Can you simply delete kunrt, then rename?
robert downes
Postby robert downes » Thu Feb 06, 2014 5:08 pm
There are a couple of issue I see with deleting each:
1) there are a decent amount of series that would need to be deleted
2) deleting would have to be done each time the program is run - even if it was written into the program, it seems a bit superfluous
Alternatively, simply using the _sa would result in just as much work as other programs & models call on these series.
Postby EViews Gareth » Thu Feb 06, 2014 5:26 pm
I'm not sure there's a better way than deleting.
