ARIMA Model + Forecast
rowbro
Postby rowbro » Thu Jan 09, 2014 3:01 am
Afternoon all,
I am currently struggling with what I suspect is a fairly basic problem, but nevertheless one I can’t seem to crack.
I have built a simple ARIMA model for inflation that estimates inflation components using 7 AR equations. The equations run together using a model, however I am struggling to figure out how to use the model to forecast each equation (3 periods) and then aggregate them (weighted) so as to produce an overall inflation forecast.
Obviously I can do each of these things manually and get the desired result, but it would be great for it all to happen at the click of a button.
Any ideas?
Thanks!
trubador
Did you use forum search?
Re: ARIMA Model + Forecast
Postby trubador » Thu Jan 09, 2014 3:07 am
Define the headline inflation as an identity:
model01.append @identity inf=0.5*inf1+0.3*inf2+0.2*inf3
rowbro
Postby rowbro » Thu Jan 09, 2014 3:18 am
Thanks trubador, and please excuse my obtuseness, but how/where do I do this? In the model or in the command line? Also, how do I ensure that the model forecasts each of the equations each time it runs?
Thanks again
trubador
Postby trubador » Thu Jan 09, 2014 5:15 am
If you have already defined and saved your model object into the workfile, then you can do it either way. The model handles equations simultaneously, so you do not have to worry about individual forecasts. Just make sure that you have selected dynamic solve for out-of-sample projections.
rowbro
Postby rowbro » Thu Jan 09, 2014 5:29 am
Thanks, I have got that aspect working, but still struggling with the forecasts. The equations I have made don't seem to forecast automatically (I don't know if this is possible), and when the model runs it doesn't forecast each equation. How does one fix this?
Thanks again
Postby EViews Gareth » Thu Jan 09, 2014 5:37 am
If the equations are in the model, solving the model will forecast from each of them
Return to “Models”
