creating weekly and semi annual dummies with @expand
Re: creating weekly and semi annual dummies with @expand
thank you guys. it worked.
i copied a set of data from excel cells into my empty worksheet.my data contained numbers. it pasted the data into my worksheet as alpha01.
so i presume they are in strings. how do i convert this to numbers and generate a series from my data.
i tried
series newnumb=@val(alpha01) and it doesnt work
can i get some help
i tried
can i get some help
it gives me NA as the inputs
also when i imported that same data from excel to eviews it was giving me NA in the cells. But when i copy and paste it,i get my data on eviews in a group with name as alpha01
but series newnumber=@val(alpha01) gives me NA in the cells
There's probably some non-numerical characters in that alpha series then.
my alpha02 values i copied from excel appear in eviews as follows and its left aligned
6 876
7 194
7 481
7 359
8 316
it doesnt appear as
6876
7194
7481
7359
8316
6 876
7 194
7 481
7 359
8 316
it doesnt appear as
6876
7194
7481
7359
8316
A space in the middle would be the non-numeric character Gareth alluded to.
thanks guys. i guess i better remove the spaces in the data from excel before i import it
It is possible that something like the following will work in EViews.
series numeric=@val(@replace(alpha02," ",""))Re: creating weekly and semi annual dummies with @expand
i tried it and it still gives NA
Probably back to Excel then. But just to be sure, the code requires no spaces between the last set of quotes.i tried it and it still gives NA
is it possible to generate a table of AIC values for my
equations
equation arma01.ls y c ma(1)
equation arma02.ls y c ma(1) ma(2)
equation arma03.ls y c ma(1) ma(2) ma(3)
equation arma10.ls y c ar(1)
equation arma11.ls y c ar(1) ma(1)
equation arma12.ls y c ar(1) ma(1) ma(2)
to
equation arma33.ls y c ar(1) ar(2) ar(3) ma(1) ma(2) ma(3)
equations
to
when i copy the correlogram graph into msword, it doesnt show the bars of the ACF AND PACF but it shows it as " * ".
how do i copy it into microsoft word for it to show the bars of the ACF and PACF
Other than by doing a screenshot, you cannot.
