hello, all
I just want to know :
can Eviews affiche the graph or a series during the execution of a program or not?
if that, I can check my graph right away other than check the calculs at last...
thks for your help!!
show the graph when executing a prog
Re: show the graph when executing a prog
It is not clear what you are asking here. But the show command can be used to open/show objects in a program.
thanks, "show " seems to be what I am looking for!It is not clear what you are asking here. But the show command can be used to open/show objects in a program.
another question: :DIt is not clear what you are asking here. But the show command can be used to open/show objects in a program.
I add the "show" command in my program, and it works, I see my graph during the execution, once the graph is shown, how can I tell Eviews to close the showed graph and proceed to the next program?
Is this clear...
thanks in advance
You can use the Close command to close an object in a program.
