Hi to all.
I would like to know if there is a command which allows me to "pause" a program for a concrete time (by code).
What I want to do is launching an eviews program, in which I launch an external software, and after some time (let´s say 3 seconds) it has to read a text file and then continue executing the code.
Another way would be that the Eviews program pauses its own execution until the external software has finished, but I don´t know either if it would be possible.
Thank you in advance
Little break/pause in a program
Re: Little break/pause in a program
That works perfectly. Also the code to check if other process is finished would be quite difficult.
Thank you Gareth
Thank you Gareth
