test for autocorrelation when estimating ARCH-Model
Michal83
Postby Michal83 » Sat Nov 02, 2013 4:41 am
Hi, I estimated in EViews 8 an equation using the ARCH-Method. In residual diagnostics, there is no Breusch-Godfrey Serial Correlation LM. Why?
How can I test for the autocorrelaction? In my equation, I use a lagged endogenous variable, so the Durbin Watson test is biased (and the Breusch-Godfrey test is not offered). Is there any easy way, how to calculate the Durbin h-statistic? Or other tests? Thank you very much in advance.
strypste
Re: test for autocorrelation when estimating ARCH-Model
Postby strypste » Mon Nov 04, 2013 6:24 am
open your equation object and go to:
view -> Residual diagnostics -> Correlogram - Q-statistic
and then click "ok".
The output will show the Ljung-Box Q-statistics and its p value. The null hypothesis is that there is no autocorrelation (See http://en.wikipedia.org/wiki/Ljung-Box_test)
forever
Postby forever » Fri Dec 06, 2013 3:59 am
Hi,strypste,could one can test the autocorrelation by clicking Proc/make residual series and then clicking view/correlogram?which one is standard?
strypste
Postby strypste » Fri Dec 06, 2013 4:15 am
I think this depends on the model you estimated.
For example:
Model 1: y c ar(1) ar(2)
Model 2: y c y(-1) y(-2)
You will see that for model 2 the two methods will show that same results, but for model 1 they will be different. In particular, the method you propose will not have p-values for the first two lags. This has to do with the degrees of freedom. Somebody else and I actually already posted a question asking why exactly this is the case. (http://forums.eviews.com/viewtopic.php? ... 718#p12565)
trubador
Did you use forum search?
Postby trubador » Fri Dec 06, 2013 6:09 am
Yes, that is correct. When the residuals from an estimated ARIMA model are used, degrees-of-freedom are reduced by the number of estimated AR/MA coefficients.
forever
Postby forever » Fri Dec 06, 2013 6:21 am
Dear strypste:
I find the two test ways are conflicted in my equation,now I think the first way is correct when you fit a ARIMA model,such as what have done in "Forecasting the Volatility of Philippine Inflation using GARCH Models". Do you agree with me? As to your question(viewtopic.php?f=18&t=3718#p12565),it should be occured in the first test way.I don't know the true difference between model 1 and model 2 all the time,as I know, the model 1 should be AR(2) model,but I don't know what mean about the model2?.Could you tell me?
strypste
Postby strypste » Fri Dec 06, 2013 6:53 am
This post explains the difference between model 1 and model 2:
http://forums.eviews.com/viewtopic.php?f=7&t=465
forever
Postby forever » Fri Dec 06, 2013 7:52 am
Thank you vary much,strypste :)
