Internal error 502
GMCS
Internal error 502
Postby GMCS » Mon Jun 01, 2009 11:22 pm
when i try to open a specific eviews workfile, a box with the message "INTERNAL ERROR 502" appears and the file does not open. Is there anyway i can fix this problem, or does this mean that the workfile is corrupted ? It would be great if i could get a response soon.
Ganesh
Re: Internal error 502
Postby startz » Tue Jun 02, 2009 5:05 am
Ganesh
A good answer is going to have to wait for morning pacific time. In the meantime, you should say what version and build date you have (under About) and possibly post the workfile.You may also want to email support@eviews.com , including the serial number and version and attaching your workfile.
Postby EViews Glenn » Tue Jun 02, 2009 6:20 am
It's not a bug...sorry to report that the workfile is almost certainly corrupted. Do you have one of the ~f1 backups available?
GMCS
Postby GMCS » Tue Jun 02, 2009 9:40 pm
Thanks for the responses.I deleted the corresponding ~f1 file. I will get the network backup tape from the day before the error occured and use that wf1 file.
Regards,
Ganesh
GMCS
Re: Internal error 502-new problem
Postby GMCS » Wed Jun 03, 2009 7:04 am
The "INTERNAL ERROR 502" error occurs when i reopen a file that failed to save successfully before.
When i try to save any eviews file, i get an error message saying "the instruction at "0x006d91ca" referenced memory at "0x0000003c". the memory could not be "read" "
after i terminate the program and try to reopen the file again, the "internal error.." message pops up. i have the ~f1 backup file available now.
Does this mean that i have to re-install eviews? i have EVIEWS 6 and unfortunately cannot provide you with a copy of the original file.
regards,
Ganesh
Postby EViews Gareth » Wed Jun 03, 2009 7:30 am
You should try installing the latest patch before re-installing.
http://eviews.com/download/download.html
Postby EViews Glenn » Wed Jun 03, 2009 10:02 am
As to the backup file, make a copy, rename it to something with the extension .wf1 and then open as usual...
