Dear all,
I am new with Eviews and i have no idea how to implement it. I would like to estimate an AR(2) with ML method and errors a t-distribution with 3 degree of freedom.
The same with errors distribution N(0,3).
Thank you beforehand.
Chuse.
Estimation of AR(2) with t-student
Re: Estimation of AR(2) with t-student
There is nothing built-in. You need to write a program using the LogL object and/or the Optimize command. You can work on the following code that I've just cooked up:
'Maximum likelihood estimation of AR(2) model with t-distributed errors
'Create a workfile
wfcreate ar2model u 250
'Generate a series that follows an AR(2) process
!rho1 = 0.6
!rho2 = 0.3
!dof = 3
smpl @first @first+1
series y=0
smpl @first+2 @last
y = !rho1*y(-1) + !rho2*y(-2) + @rtdist(!dof)
'Declare coefficent vectors and assign initial values
coef(2) rho = .5
coef(1) dof = 2
coef(1) var = 1
!pi = @acos(-1)
'Initialize presample values
series res = 0
'Set up logl object
logl ar2t
ar2t.append @logl maxlik
ar2t.append res = y - rho(1)*y(-1) - rho(2)*y(-2)
ar2t.append sqres = ((res^2/var(1))/dof(1))+ 1
ar2t.append maxlik = @gammalog((dof(1) + 1)/2) - @gammalog(dof(1)/2) - log(!pi)/2 - log(dof(1))/2 - log(var(1))/2 - (dof(1)+1)*log(sqres)/2
'Use the following spec. for normally distributed errors
'ar2t.append sqres = res^2/var(1)
'ar2t.append maxlik = log(@dnorm(@sqrt(sqres))) -log(var(1))/2
'Run MLE and display results
smpl @first+2 @last
ar2t.ml(showopts,m=1000,c=1e-5)
show ar2t.output
'Get the gradients
ar2t.makegrads(n=gradslogl) gradlogl1 gradlogl2 gradlogl3 gradlogl4
'We can also use Optimize instead of LogL
subroutine loglikelihood(series logl, vector beta, series y)
series res = y - beta(1)*y(-1) - beta(2)*y(-2)
series sqres = ((res^2/beta(3))/beta(4))+ 1
logl = @gammalog((beta(4) + 1)/2) - @gammalog(beta(4)/2) - log(!pi)/2 - log(beta(4))/2 - log(beta(3))/2 - (beta(4)+1)*log(sqres)/2
endsub
series logl
vector(4) beta
beta(1) = .5
beta(2) = .5
beta(3) = 1
beta(4) = 2
optimize(ml=1, finalh=hessmat, hess=opg) loglikelihood(logl, beta, y)
vector semat = @sqrt(@getmaindiagonal(-@inverse(hessmat))) 'standart errors of estimated coefficents
smpl @all
Thank you very much. It work very well.
Now I would like to construct the estimation erros of the QML method using the score function. I checked that there is possible to get it as a table of the gradients.
But i dont know how to manipulate it, e.x. how can i get the Hessian matrix?. could you please help with it?
It is quite difficult to construct the Hessian matrix from the estimation results of LogL object. Therefore, I built the same model within the user-defined optimization framework, which also produces that output. I do not recall whether it was possible to retrieve gradients via the Optimize command, but it is with the LogL object. I've edited the code in my previous post, where "gradslogl" is the group of gradients and "hessmat" is the final hessian matrix.
Thank you again, Trubador. Using both methods I can construct the standard errors for QML. :)
