Line Graph is turning into Dot Graph
rmoralesaramburu
Postby rmoralesaramburu » Tue Nov 26, 2013 3:48 pm
Hello
I am trying to program a line graph and it is turning into a dot line. I suppose it is because of the NA values, but is there a way to handle it?
I am attaching the .prg and .wf1 file.
Thanks.
variaciones.prg
(319 Bytes) Downloaded 398 times
variaciones boletín.wf1
(18.23 KiB) Downloaded 357 times
Re: Line Graph is turning into Dot Graph
Postby EViews Gareth » Tue Nov 26, 2013 4:10 pm
Add:
posi.options connect
Postby EViews Gareth » Tue Nov 26, 2013 4:33 pm
As an aside, you're probably better off using this wfopen command (which should mean you won't need the connect option):
wfopen(page=posi) "H:\4. Benchmarking y Optimización\Set del Morning Meeting\Variaciones Boletín.xlsx" byrow range=cambios!f13 @freq w(mon) @id @date(date)
rmoralesaramburu
Postby rmoralesaramburu » Wed Nov 27, 2013 6:25 am
Thanks, the first solution worked out perfectly.
The second solution I am getting this error:
"Date is not defined in "wfopen(page=posi) "H:\4. Benchmarking y Optimización\Set del Morning Meeting\Variaciones Boletín.xlsx" byrow range=cambios!f13 @freq w(mon) @id @date(date)"
