I have a matrix A , what i want to do is if each factor is greater than 65, then matrix B= (factor-65), else factor returns 0.
I tried to create a new matrix S full of 65(same dimension as matrix A) and using code
matrix new_A = (A>65)*(A-65)+(A<=65)*0
However, it returns a matrix full of 0(@recode can't be used in matrix calculations).
Thank you!!!
Similar question to previous post, except it is a matrix.
Re: Similar question to previous post, except it is a matrix.
When you say "factor" do you mean element?
If so, you can use a couple of for loops to loop through the matrix element by element:
matrix new_a = a-65
for !i=1 to @rows(a)
for !j=1 to @columns(a)
if a(!i,!j)<=65 then
new_a(!i,!j) = 0
endif
