VAR Data Members
RDS
VAR Data Members
Postby RDS » Tue Nov 05, 2013 10:36 am
I need to save the Schwarz criterion and the log likelihood of a specific equation of a VAR.
This for example doe not work:
var example_var.ls 1 2 x1 x2 x3
scalar loglikelihood = example_var.@eqlogl(1)
scalar SC = example_var.@schwarz(1)
Re: VAR Data Members
Postby EViews Gareth » Tue Nov 05, 2013 10:49 am
VAR data members are located at the start of the VAR section of the Object Reference.
Each object's data members are located at the start of its section in the Object Reference.
RDS
Postby RDS » Tue Nov 05, 2013 11:10 am
Yes, I looked at the Object reference. As said this does not worK:
scalar loglikelihood_x1 = example_var.@eqlogl(1)
scalar SC_x1 = example_var.@sc(1)
The numbers I get are not those reproduced by EVIEWS in its Vector Autoregression Estimates.
Postby EViews Gareth » Tue Nov 05, 2013 11:25 am
Ah, sorry, I missed the part where you said you wanted the equation specific one. Only the system wide ICs are available from the VAR, not the equation specific ones.
You can, of course calculate it though:
create u 100 series x1=nrnd series x2=nrnd series x3=nrnd var example_var.ls 1 2 x1 x2 x3 scalar loglikelihood_x1 = example_var.@eqlogl(1) !t = example_var.@eqregobs(1) !l = example_var.@eqlogl(1) !n = example_var.@eqncoef(1) scalar SC_x1 = -2*!l/!t + !n*@log(!t)/!t show example_var show sc_x1
RDS
Postby RDS » Tue Nov 05, 2013 11:35 am
These are the number of your VAR
x1 x2 x3
Log likelihood -144.4427 -132.9798 -138.4324
Schwarz SC 3.275307 3.041371 3.152648
and these are the values of your scalar sc_x1 = 8.78354 and loglikelihood_x1 = -414.34622
They are very different.
Postby EViews Gareth » Tue Nov 05, 2013 11:41 am
In mine they match. What's the version and build date of your copy of EViews (Help->About EViews)?
RDS
Postby RDS » Wed Nov 06, 2013 1:43 am
Version 7.2
Enterprise edition Sep 23 2011 buid
Postby EViews Gareth » Wed Nov 06, 2013 7:58 am
Update to the latest version.
RDS
Postby RDS » Thu Nov 07, 2013 11:01 am
There is a bug in eviews 7.2?
Postby EViews Gareth » Thu Nov 07, 2013 11:16 am
Well that might explain why you're not getting matching results. Your copy is very out of date. There have been 46 patches since your version, each of which contains multiple bug fixes.
