Hi Guys,
I basically want to fetch data from a previous database I have created, rename my forecasts to historical data, then overwrite the previous historical data (which had the same name) Here is the code:
fetch(d=forecast_updaug13_c{%country}) *
copy *_f *_t
rename *_t *
However, I keep getting the error "Variable X" already exists in "Rename *_t *"
Ultimately I just want to fetch all the data in my db and rename anything with _f (e.g. example_f) to without the _f (e.g. example) however, the variable "example" here already exists in the database I'm reading in and it wont let me overwrite it. I would try just fetching the _f data but I need some variables which aren't _f to complete my modelling.
Hope this makes sense, my english isn't the best I know!
Fetching data and overwriting existing data
Re: Fetching data and overwriting existing data
You'll have to delete the existing ones first.
eugh! Was afraid of that. Is there any way to delete something only if it exists? If not, don't delete?
The delete command has an option to do that:
delete(noerr) objname
