Problem applying weakinst command eviews7
andreaskyriacou
Hello. I am trying to apply the weak instrument command in eviews 7. As suggested by the help option I write the equation name and then the command which in may case means eq03.weakinst (eq03 is a previously saved regression employing panel two stage EGLS and applying Period Sur GLS weights.). The problem is that eviews 7 gives the following error message "Equation estimated using a previous version of Eviews. Please re-estimate the equation before running this test." While the workfile was created with eview 6 the equation was estimated with eviews7. And when I re-estimate the equation I get the same message. Any clues?
Re: Problem applying weakinst command eviews7
What is the build date of your copy of EViews 7? (Available from Help->About EViews)
andreaskyriacou
It's a version 7.1 standard edition may 12 2010 Build.What is the build date of your copy of EViews 7? (Available from Help->About EViews)
Update to the latest version (Help->EViews Update)
andreaskyriacou
I am trying to update but am getting an error message stating An error occurd during update dowload. Please try again later. Is the problem on my end?Update to the latest version (Help->EViews Update)
Possibly. You can download it manually from here:
http://eviewsupdates.s3.amazonaws.com/E ... 101713.exe
andreaskyriacou
OK. Have downloaded the latest version (in my case 7.2). Unfortunately still get the same message when trying to do weakinst. From help option have seen that another way of performing diagnostic is to "click on View/IV Diagnostics & Tests/Weak Instrument Diagnostics". When I estimate the equation and go to the view option, I don't see the IV Diagnostics and Tests option. Hope you can help out.Possibly. You can download it manually from here:
Ah, you're estimating a panel equation. EViews doesn't have the weak instruments diagnostics available for panels.
