corrected White test output
yay.emet
Postby yay.emet » Thu May 28, 2009 11:43 am
how do I run a regression (obtain output) that is corrected for heteroskedascity (white correction)?
:?: :D
trubador
Did you use forum search?
Re: corrected White test output
Postby trubador » Thu May 28, 2009 1:29 pm
Open the equation dialog (Quick/Estimate Equation) and specify your model (e.g. y c x1 x2). Then go to the "Options" tab and check the "Heteroskedasticity Consistent Covariance". The default is "White", so when you estimate your equation, standard errors in your output will be computed using "White's Covariance Estimator".
yay.emet
Postby yay.emet » Thu May 28, 2009 10:42 pm
thank you, appreciate your help (:
flash
Postby flash » Sat May 30, 2009 6:53 am
following the same issue, how do I run a regression with White corrected errors using the command line ?
Thanks in advance :)
trubador
Postby trubador » Sat May 30, 2009 7:42 am
equation eq1.ls(h) y c x1 x2
