Problem Adding Variables to Group
RPEDC
Postby RPEDC » Fri Oct 04, 2013 11:44 am
I'm generating a series that is a combination of other series for a number of variables. However, when I run the program with the code, it only generates the variable for the very last item in the loop command and adds that to the group I'm trying to create. What I have coded is below. What am I doing wrong with the code?
for %i USA AFG ALB ALG ANG AGL ANT ARG ARM ARU AUST ASTR AZE BAHA BHR 'CREATE DUMP GROUP Group _Tenth '****NED_CAE genr {%i}_NED_CAE = ({%i}_TD)/ ({%i}_EXP + {%i}_SER) group _TENTH.add {%i}_NED_CAE next
For example, what would happen to me here is that I'd open up the group "_Tenth" and only see the variable BHR_NED_CAE in the group.
Re: Problem Adding Variables to Group
Postby EViews Gareth » Fri Oct 04, 2013 11:59 am
Create the group outside of the loop.
